Originally posted by Tom S. Be very careful about believing information you see on RiceHigh's blog as he has been known to distort and ignore facts.
I agree; RiceHigh does tend to be very unreliable. However, if you google "pentax flash underexposed" you will get a lot of hits.
What I can't work out is if this is a general problem with P-TTL, or if it is a common fault, or issues with some usage modes.
If it's a general design problem with P-TTL, then I do not want to spend extra $ to get a 540.
If its a common fault in pentax flash units, then I will get a 540, but make sure it is easy to return for a good unit.
If it's a problem in some modes of use, or there is a work around, I'd love to find it!
BTW, moving to manual mode would fix the problem, but removes any benefit from buy an expensive flash unit.
Thanks,
Jonathan
