Can somebody please shine some light on the following problem? Last week, I was shooting an event for the client. I used one of my Cactus RF60X flashes, mounted directly to the camera (Pentax K1-Mark II). I took a few shots using the flash. Then, the flash didn't fire, but the red light was on.
Additional information:
- I was using rechargeable Eneloop batteries and a Cactus external battery pack EP-1 (total of 12 AA batteries); all batteries were fully charged
- The recycle time after a full power flash (using the Cactus external battery pack) should be 1.2 sec
- Lens used - HD Pentax DFA 24 - 70 mm
- The camera was set at the Flash synch speed of 1/180 or slower; ISO was set at 200 or higher to maintain a faster recycle time
- Cactus RF60X was set in L mode and 1/4 power
- Firmware of the Pentax k1 - II is v 2.30
- Firmware of the Cactus RF60X is 104.
I also have a Transceiver V6 IIs (firmware 1.1.013), but this device wasn't used in this instance.
As it happened repetitively, first of all, I checked if the flash was correctly mounted on the camera, and it was. I turned off both devices (flash and camera) and removed the batteries from the flash unit. Then, I turned back on both devices. On a few occasions, everything worked as it should, but it didn't last. I'm lost what could be the problem. Please help!
Questions:
- Could it be the Capacitor? If so, I have followed the instructions per User Manual #15. Forming the Capacitor. This was after the event.
- Can I do any tests to determine if the flash unit is the problem? I have two external flash units and must prevent this issue from reoccurring.
- Could the old firmware be causing this problem? Where can I download the latest firmware for Cactus RF60X for Mac?
Thank you, guys; I appreciate any tips on how to fix this issue.
