Originally posted by menappi Out of the af280 or the promaster..which might be a better investment. If the promaster is a decent flash then i wouldn't mind spending the extra money on it if it will stay on my camera for a while...
*both these will work on a k100d, correct? I'm kind of having trouble understanding the technical lingo about flashes..any good resources to learn the basics? I saw the strobis and it seems to be more techniques but it is bookmarked for now.
I don't know anything about the Promaster but if it doesn't do P-TTL than all it does is work in A mode or manual on a K100D. The AF280 is exactly the same, no automation other than the flash metering for itself.
What this means in use is that you have to set the flash to one of the A settings with a switch, set the ISO to match what your camera body is set to and read what aperture the flash tells you to use.
Next, you set your camera in manual, set the lens aperture to what the flash is telling you, set the shutter speed to anything 1/180th or below. The flash also gives you a range of distances that it will be effective based on all of this informaiton. As long as your subject is within that range, the flash will expose correctly.
If all of this sounds too complicated (it sounds much worse than it is) you may want to spring for a P-TTL capable flash. That is the only way to get the kind of automation that the popup flash has.
