I've only had this since Friday & it was raining on Saturday so I've not had a chance yet to use this seriously, but I've taken quite a few shots in the house & in the garden. Here are my initial comments.
The assembly shown on a K20D. The flash is relatively tall. At the top of the flash reflector you can see the lip of a pull-out, spring-fold-down wide-angle diffuser panel. When this is pulled out & down it covers about 85% of the width of the flash reflector and allows the flash unit to go below 24mm (Film)/16mm (DSLR) coverage to 17mm (Film)/11mm (DSLR).
The zoom flash head has 7 FL steps:
Code:
Film DSLR
24 16
28 19
35 23
50 33
70 47
85 57
105 70
With an F or later lens, the flash will automatic track the lens FL. The display always shows the film FL. For example with a DA 16mm-45mm zoom it shows 24mm & 70mm at the two extremes of FL on the flash's display. I would prefer it to have an option to show the DSLR FL instead.
Below the flash head you can see the red AF Auxiliary Light. As well as flashing briefly in LL situations to help the AF (its range is 0.7m-9m (2.3'-29.5')), it also flashes slowly & regularly in off-camera slave mode to remind you that the flash is operating in this mode.
Here is a side view with the battery compartment open. I find the compartment lid a little fiddly. The slanting design, the long flash head & the relatively high & forward battery compartment location means that there is a lot of weigh to the front of the flash mount. This tends to pull the front of camera down when you carry it on a neck strap. Li batteries, an upright shape & locating the battery compartment lower would have produced a better product, in my opinion.
You can bounce the light up or to either side. Vertically, there are indentations at -7 (depressed a little for close-ups), 0 (straight ahead), 60, 75 (inline with the slanted body), 90 degrees (straight up), but puzzlingly, not at 45 degrees. You can still set it at the approx. intermediate position, but a click stop would have been appreciated.
The LCD layout is a bit sparse & seems illogical. Above you can see a "P". This means the flash is currently running P-TTL. The "P" should be up next to the "TTL" indication. On the left you have the flash EV indicator showing that EV is applied and on the far right the value of EV (+1) applied. They should be next to each other. Also I can not understand why there is not an option to just show metres or feet. Showing both just wastes screen space and makes the display a bit harder to interpret.
When I first tried the flash on a K20D it was far too under-exposed. I found I had to use the maximum of both the camera's flash EV & the flash unit's EV compensation (+1.0 in both cases) meaning that overall the unit needs about +2.0 EV to correctly illuminate. However once I applied this, the exposures seem good. This may be correctable through rechipping, but I bought it from O/S and don't want to go through the expense & delay of sending it to Sigma for alteration. I'm prepared to live with it as long as the EV adjustments are sufficient.
The flash unit will hold the settings for at least a few minutes so you can turn it off, have it auto power-down or change the batteries and still keep the EV setting, but you will need to reselect it after a longer delay, like leaving the unit unpowered while recharging the batteries. Swapping to a 2nd set of batteries would alleviate this minor concern. It's better this way then losing the settings more quickly.
So far, I've also tried out:
HSS (high speed sync) - using the flash unit with a camera shutter speed faster than 1/180s - the unit calls it FP (Focal Plane).
Slave mode - using the Sigma 530 on a stand away from the camera and relying on the camera's built-in flash to trigger it. (Wirelessly).
Multi mode - stroboscopic multiple flashes during one longer camera exposure to show multiple steps in an action.
M (Manual) mode - I tried this with a Pentax-M 50/F1.7 and got a correct exposure after 2-3 attempts. I used the distance display on the flash's LCD to estimate how much I had to change the flash's output level (e.g. 1/16th of full output). I was rather pleased that I got this result with a few different photos so early in the learning curve. I consider that, with experience, Manual mode should not be too difficult to work with. Perhaps the experience I gained struggling using the built-in flash on the K100DS & K20D with Pentax-M & M42 lenses has helped a bit.
Followup: I just tried a series of night-time shots of the same object with this M lens: ISO200, F5.6, 0.3s, 1/10s, 1/60s, 1/125s 1/180s. I decided to set the flash output level to 1/16th full output. The distance graph shows 13m (40') - instead of a range of distance bars, it just has a sole bar at the matching distance. All shots were correctly exposed. I thought I would need to adjust flash output level in each case, but no. I then tried it at 0.3s without flash. It was about a stop down. This indicates that when the exposure from the flash (very fast) is much larger than the contribution from ambient light even with a much longer exposure, then the overall exposure is determined by the flash output level (and lens aperture), not by the shutter speed. I've still got plenty to learn.
The unit was not that expensive ($220 USD) and I got it from 47th Street Photo NY.
By, the way the shots were taken with a K100DS with Mk. II kit lens, and holding that compared to the K2D0 + DA 16-45/F4 + Sigma 530 Super makes my old camera feel almost like a toy in size & weight.
Dan.
