Originally posted by FotoPete Sorry I don't understand much about flash. I really just need it for better lightning so an auto one with be nice. I also read that my GX-1L (by virtue of being an *ist DL2 clone) doesn't have TTL.
It does not have the old analog TTL, but it has the newer digital P-TTL system.
Basically, there are three ways of achieving proper flash exposure. The first is the manual way, where you calculate the distance/aperture; and this is most tedious and time consuming.
The second is the "Auto Flash" using the sensor in the flash. Based on the ISO, you can set the flash auto setting at a specific aperture value. And you then set the camera to the same aperture value (using Av or M mode), the flash unit would shut off the flash firing when the proper exposure is achieved. It is much easier than manual, but it is not TTL.
P-TTL is the most sophisticated one, and you need a dedicated P-TTL flash unit. Basically, the external flash would function EXACTLY like your built-in flash. I.e. you have the freedom to use any modes (P, Av, Tv, M, Picture), any aperture values (within the flash range), and the flash would calculate everything for you. It utilizes TTL multi-segment metering, and will automatically compensate for any filter use, bounce or different focal length lenses.
P-TTL also offers you some advanced flash feature not available otherwise, such as High Speed Sync (syncing up to your max shutter speed), multiple wireless TTL flash (need two or more flash units) and flash exposure compensation. And P-TTL flash such as Pentax ones (360 / 540 FGZ) give you options of using P-TTL, Auto or Manual flash.
For seamless integration and ease of use, I would recommend getting a P-TTL flash unit. But it would be more expensive than using manual or auto flash. Be careful when you are using an older flash unit. Some older models have very high trigger voltage and can cause serious harm to your camera.
