Originally posted by beth_w737 Hi,
I'm going to Costa Rica (you may have seen my other threads in the lens forum) - and will either have the 50-135 DA or 55-300. (unless I rent the 300 F4 but getting nervous about the weight and chance of theft). I don't own a flash, only have the popup flash on my K10D. What external flash would you suggest, especially that would be compatible with the Better Beamer Flash Extender?
Thanks for your help. If I have a fast 2.8 lens, do I need an external flash, do you think?
Beth
The user zardozfromoz has the better beamer :
"> You know, I felt a bit embarrassed getting the thing out of my bag
> and putting it on the flash, because it's pretty big compared to what
> most people expect. I was also worried that it would fall off since
> I'd be doing some pretty agressive panning when I was down the fast
> end of the track.
>But my fears were unfounded. It was very easy to
> set up and use, and nobody laughed at me! As I mentioned, it got the
> attention of at least one serious photographer. And it handled the
> panning without budging, all with only the velcro straps that came
> with it. You have to make sure you get the correctly sized unit for
> your flash, though. All of the dealer websites fail to list the
> AF-540FGZ unit so you can't work out the right size. It took me ages
> searching the web before I found a girl who shoots birds with one on
> her AF-540FGZ. She told me the right one to buy, and I was all set.
The correct one for the AF-540FGZ is the FX-2."
I've also heard of other combinations.
and
Better Beamer Flash Extender Review
I'm considering the Metz mecablitz 45 CL-4 digital.
Also check out Dominique/Tcom threads from Madagascar. I think he used the better beamer
