Originally posted by snostorm Hi Nimrad,
The only other thing that I can think of is make sure that the flash is set to Slave I. Press and hold the "Light" button until the LCD changes and you'll see "Slave" and either "1" or "2". You want "1" for wireless TTL. Slave "2" allows the flash to be used as a dumb optical slave. pressing the "S" button in the middle of the rotating dial toggles between the two.
Scott
I already did that as that was a step in the manual.
Originally posted by Leaf Fan IIRC you have to use the flash in the hotshoe first just to get them both (body and flash) set to the same channel. then you can remove it and fire wirelessly using the onboard flash as the master and the 540 as the slave. I've done it a few times and it's worked fine.
If none of the suggestions here work, take it to where you bought it and ask them if you're doing something wrong or if it's the equipment.
Good luck.
Originally posted by Nimrad chose channel 3 just to check if my K20D communicated with it and received the right channel. It did.
Please read the posts before answering :>
But thanks for the tips, no luck yet. And since the place I bought it is on the other side of the Atlantic I still don't know what to do.
One more question: Do I have to open the onboard flash? Cause even if I have it on wireless mode my onboard flash just fires like it was the master flash.
