Hi Folks,
Hoping someone can help me with advice on this:
I have the following equipment:
K100D
Metz 48
Centon FG30
I would like to construct a set up whereby I can use the three together in one (or both) of the following configurations
K100D built in flash & the two other flashes remotely
K100D with Metz 48 attached & Centon FG30 remotely
K100D (no flash) and the two other flashes remotely
The Centon FG30 has a manual setting & two thyristor (I think) auto settings and has a PC (I think this is the correct terminology) socket.
The metz does not appear to have a PC socket but I believe it can be fired wirelessly (but not by the K100D?)
I have been trying to research this on the web but am getting a bit lost in jargon and terminology so if someone could offer any advice I would be very grateful.
I would like to be able to do this outside aswell as inside.
Any idea what sort of set up i need - cables, adaptors etc? And just to be restrictive, cost is an issue so the wireless pocket wizard gadgets are out
thanks in advance for any offerings.
