Originally posted by SOldBear Try this:
Attached the 160 to the camera body. The 280 will be attached to an optical slave.
Match the ISO settings on the flashes and on the camera body.
Flashes will be in auto mode.
Set the aperture on the camera body so that it is 1 stop underexposure compared to the setting on the 160, and 1 stop overexposure compared to the setting on the 280. You may need to play with different ISO settings and/or different power setting on the flashes to achieve this.
Take test photos, and adjust if needed.
optical slave - do you mean sensor that triggers the flash when it registers another flash going off?
that suggestion will be hard to realise because auto setting on both AF280 and AF160 @ ISO100 is f4, though 280 can be set to auto f8 @ ISO100, so then it could work...
how about my idea with wire? any comments on that?
BR
