04-03-2009, 06:18 AM   #1
panoguy's Avatar
Why is SR disabled in wireless flash mode?
Okay, so I'm a total noob at off-camera flash, but I'm wondering *why* is Shake Reduction automatically turned off when the Flash Mode is set to W(ireless)?
Does this have something to do with acceptable shutter-speeds for flash? (I guess trailing-curtain sync won't work in Pentax wireless...).
Thanks for any illumination (pun) on the topic!
04-03-2009, 07:49 AM   #2
I think they needed the CPU cycles for commander mode. They thought SR doesn't matter anyways since a flash's strobe pulse will freeze any action lit by the flash...
Sucks that we can't use the popup flash in this mode as a focus assist light (no flash) though...it just turns off SR so doing handheld low light work is harder...
04-03-2009, 08:13 AM   #3
ManuH's Avatar
QuoteOriginally posted by panoguy Quote
I'd guess it's probably a matter of timing. Fortunately with flash you don't really need SR.
04-03-2009, 08:49 AM   #4
panoguy's Avatar
QuoteOriginally posted by ManuH Quote
Well, I've actually done some shots where keeping the background from being all black required a slower shutter and the flash just pops the foreground (SR makes a world of difference under 1/20).
I'm just waiting for my Cactus V4 triggers to arrive from Taiwan so I can forget about this problem (and kiss P-TTL goodbye in the process...).
04-03-2009, 09:54 AM   #5
Gooshin's Avatar
QuoteOriginally posted by kenyee Quote
you sure about that? give it a try, when i was testing the wireless mode the other night i swear i had the popup flash (even in controller mode) illuminate my subject when i turned the lights down.
i'll try again today,
04-03-2009, 10:20 AM   #6
I don't know why SR is disabled but wireless mode is only relevant with Pentax flashes or perhaps third-party flashes dedicated to the Pentax. Non-dedicated flashes, like my old Vivitar 283, don't need it and can't use it. No problem for me because I set the flash mode on my K10D to Flash On and Flash Comp to -1 or -2. I have a tiny Wein slave on my 283 which is engineered to ignore the Pentax pre-flash. Thus the on-board flash is primarily a trigger for the 283 while providing a little fill and putting some catchlights in the eyes.
The only problem with this setup is when photographing events where other people are popping their flashes. I have to keep my hand over the Wein sensor to keep it from being triggered by those flashes. A radio slave would be more appropriate in those situations but I don't do enough events to justify the expense.
Richard
04-04-2009, 04:43 AM   #7
Arjay Bee's Avatar
If you are using wireless mode perhaps it assumes that the camera will be in a studio setup and that you will be using a tripod in any case so you would then turn off SR, so it does it for you.
flash, lighting, photo studio, strobist
AF360FGZ won't flash in wireless mode thatguyyoulove Flashes, Lighting, and Studio 16 10-19-2010 05:08 AM
K-7 flash in Wireless mode. Doesn't work correctly? Edvinas Pentax DSLR Discussion 7 09-07-2010 06:14 PM
Wireless flash disabled on K200D when 3 sec remote delay is used? cdurfor Pentax DSLR Discussion 0 04-09-2010 05:58 AM
help with 360 flash + k200d wireless mode adamkean Troubleshooting and Beginner Help 0 03-14-2009 02:02 PM
SR Disabled in Wireless Flash Mode? Old Timer 56 Pentax DSLR Discussion 5 01-06-2008 10:02 AM
All times are GMT -7. The time now is 10:26 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
