Originally posted by mattdm (Edit: unless you have it turned on already and should turn it off, of course.)
I think you are right on this. It would be one step behind, so at 70mm (105mm eq.) would be at 85mm.
9.6 Extended Zoom Mode („Ex“)
In extended zoom mode the zoom position of the main reflector is reduced to
one level below the focal length of the camera lens. The resulting expanded and
broader light coverage provides additional dispersed light (reflections) inside
rooms so that a softer flash illumination is possible.
Example:
The focal length of the camera lens is 50 mm. The extended zoom mode sets a
35 mm reflector position on the flash unit. However, 50 mm continues to be
shown on the display.
Setting procedure
• repeatedly press button combination „Select“ until „Zoom“ appears in the
display and „Ex“ flashes. The required settings can be applied using the ( + )
and ( - ) buttons.
- When „Ex On“ is displayed, the extended zoom mode is activated.
- When „Ex OFF“ is displayed, the extended zoom mode is deactivated.
The setting takes effect immediately. After about five seconds the display stops
flashing and the setting is saved automatically. After activation of the extended
zoom mode „Ex“ appears in the display.
Depending on the system, the extended zoom mode is supported for lens
focal lengths of 28 mm or more (35mm format). The camera must be
equipped with a CPU lens and be able to transfer data on the lens focal
length to the flash unit.
edit: Thinking about this again, if the zoom display was set previously, then it is possible the flash is just reporting the correct focal length for the sensor format.
Thank you
Russell
