05-12-2009, 09:58 AM   #1
TTL mode with AF-540FGZ flash gun
I can't get my AF-540FGZ flash gun into TFF mode. It seems to me that, when the gun was new, I was able to access all modes. Has anyone else had this problem? Is it a problem or is this typical when used with a K10d?
Thanks for any help.
BD
05-12-2009, 10:17 AM   #2
Venturi's Avatar
Just to make sure we're on the same page... none of the "K" series DSLRs support TTL mode. They are all P-TTL. The AF540 supports TTL metering only for TTL camera bodies - the last bodies to support this were the *ist DS and *ist DS2.
05-12-2009, 12:21 PM   #3
Lowell Goudge's Avatar
QuoteOriginally posted by Venturi Quote
How true, and then, I believe only if the lens is a non auto apature lens.
If you want to shoot TTL mode, and asuming you have an *istD, DS or DS2 then you need to take your lens out of the A position with the AF540FGZ, or use an older flash such as the AF500FTZ which only supports TTL, then the camera will work in TTL mode
05-12-2009, 07:24 PM   #4
Thanks folks. I was perplexed but this helped.
BD
af-540fgz, af-540fgz flash, flash, gun, lighting, mode, photo studio, strobist, ttl mode
P-TTL flash - Camera in Manual mode - ISO shouldn't change exposure right? José Ramos Flashes, Lighting, and Studio 5 05-29-2010 10:00 PM
TTL auto on 540FGZ coa75 Pentax Camera and Field Accessories 12 01-17-2010 04:57 PM
K200D not compatible with 540FGZ P-TTL? xy1981ca Pentax DSLR Discussion 27 07-16-2009 07:32 PM
AF-540fgz flash in manual mode prblack.6206 Flashes, Lighting, and Studio 1 07-05-2009 03:21 AM
Dual 540fgz - *NON*wireless ttl EdZarts Pentax Camera and Field Accessories 5 04-16-2007 09:48 AM
All times are GMT -7. The time now is 03:47 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
