I recently restored a Sunpak 611, a Sunpak 522, a Metz 45CT4, and a Vivitar 283, with a Sunpak 544 in the work (not sure if I can salvage this one).
They have one thing in common: the flash head covers only as wide as 35mm (in 35mm format terms).
I don't want to buy a wide angle panel for each of them. Rather, I'd like to have one that fits all. I know bouncing against walls & windows helps but many times I don't have any place to bounce against.
I need something small (when not in used) and light, and quick to attach to and deattach from the flash head.
Will
this one work?
