hi,
from searching the forums, i haven't found any way to stop pre-flash from happening on the k10d other than using non-A lenses. can anyone confirm that this is true?
what i'm wanting to do is use both the built-in flash and remote flashes in manual power setting mode, ala the strobists philosophy (built-in only flashes to illuminate scene, remotes trigger on that flash to also add light)
I have a sigma 530 DG super flash, and it works nicely in wireless PTTL using the built-in flash as a controller/source, but i'd like to have more creative control on the power settings on the remotes.
i know i can use wireless triggers (cactus, PW, etc.), but that means no use of the built-in flash.
i also know i can get a simple flash to attach to the camera and let the sigma trigger in manual mode off that, but really, is there no way to use the built-in
-without- pre-flash happening? or some setting on the 530 that keeps it from reacting to the pre-flash?
many thanks, o mighty forum gods!
kauaiguy
