Originally posted by matchz I just did one test and I found out the result is interesting. Perhaps it is described in the manual but I just miss it.
When the flash is in M mode, I press the "Select" and activate the SL mode. It seems that the Metz48 will fire full power. The object I was taking in the test shoot was just white off.
When the flash is in PPT mode, I press the "Select" and activate the SL mode. The Metz48 will fire the flash required. The exposure was correct.
However, if I set the power to 1/8 or 1/32 in M mode first then activate the SL mode, the flash will still fire full power.
Note that while in SL mode, by cycling through the settings using - & +, you do not see a manual setting but an Ev flashing.
In Slave mode, you cannot use manual power. This is what we were trying to describe above.
You can only use compensation in terms of Ev
