Originally posted by SOldBear From what I know (not a lot BTW), the Promaster FTD 7000M does not has its own light sensor so it doesn't matter whether you set it at TTL or manual, it always fire at full power with Kxxx Pentax DSLRs.
You need to adjust the camera's ISO setting and the lens's aperture setting depending of the distance from the flash to the object.
The GN changes with ISO. Aperture setting = GN / distance.
It doesn't have an Auto mode, so it is true manual. The 7000m does however let you adjust the power level in manual, from 1/1 tp 1/64, so it isn't only just the camera settings that can effect the exposure.
Thank you
Russell
