Originally posted by HeavyD I read in the manual that when I change the flash compensation through the camera, it's suppose to change the value and show it on the flash lcd as well correct? .....
It doesn't, not with changing flash compensation on the flash itself.
It only shows when you set flash compensation on the camera, and its additive.
I.e. if you set +1 on the flash and +1 on the camera, you end up with +2 E/V flash power, assuming you haven't exceeded the maximum power of the flash. I found that out once when I heavily overexposed a shot, and only realised later I had forgotten about the +1 compensation set on the flash.
