Originally posted by GeneV Do the current crop of dedicated flashes automatically add EV compensation when the heads are in bounce position? Some of the old Vivitars did that.
What do you mean by "add EV compensation when the heads are in bounce position"?
In P-TTL or TTL mode, the light output is determined by the light sensor in the camera body.
In A mode, the light output is determined by the light sensor in the flash body.
In P-TTL/TTL/A modes, if the head is in bouncing position, in order for the sensor (either in the camera or in the flash body) to receive the same amount of light, the light output of the flash will automatically increase.
In M mode, the light output is determined by the power ratio setting (by the user).
I'm not sure if I answered your question.
