Originally posted by Photomy Even best flash system will have problems in some situations when there are objects having several distances from camera. Also, any reflective objects, or other light sources in the field of view might confuse the flash.
With digital you can easily test with a mid-tone target all in about the same plane and see how the flash does at different distances. Then add bounce and test same target. Bounce will reduce range of flash greatly of course.
This overexposure problem is not an issue of distance or surroundings. The overexposure is consistent anywhere within the expected bounce range, and consistent with virtually any object (bounce card, wall, ceiling, whatever). Surrounding objects attenuate or enhance the overesposure, but are not the cause of it.
Anyway, I should not be seeing this type of consistent overexposure with a TTL compatible flash unit. As you know, the camera is supposed to control the level of light output for proper exposure, just as this unit does fairly well for straight-on flash images. But when the head of this unit is tilted for bounce pictures, it is as if it resorts to full power with no TTL control whatsoever.
--- > Okay, I was fiddling with the flash after writing the above (tilting the head up and down, etc), trying to think of anything to add, and it just went entirely dead on me - LED's half on with power switch in off position and LED's off with switch on. No flash whatsoever. Reinserting the batteries did not restore normal operation. This unit is clearly defective and will be returned for a replacement. Hopefuly the next one will not have the overexposure issues.
Regardless, thanks for the replies and suggestions.
stewart
