Russell,
Laying flat, the flash is 5 3/8" x 2 3/4" (L x W). It is isn't perfectly rectangular, so those would be the longest dimensions.
The head is a little more difficult to measure. I will give you measurements from the top of the hinge - 1 3/4" x 2 3/4" (L x W).
Originally posted by Russell-Evans Does it have the SB only mode?
Can you give the measurements of the flash when flat, please? The manufacturer's measurement are usually of the flash when folded.
Can you also measure the head, please? I'm wondering if there is a snap on diffuser that will work.
Thank you
Russell
Originally posted by Russell-Evans The Metz 48 AF-1 has a spot beam mode.
"In the spot beam mode, the AF measuring beam can be used to focus on a subject at low ambient light level without firing a flash when the shot is taken."
Thank you
Russell
I forgot about the spot beam mode on the 48. Sadly I can't figure out any way for that to work on my K200D. There are literally no controls beside On/Off on the flash itself. Hope that info helps.
Joe
