By "Auto" mode you refer to the camera's green mode? Please post a sample pic with EXIF data intact.
Are you using a diffuser?
In the camera flash setting, is the +/- set on 0? I am not actually sure that affects the hot shoe but might as well find out here if you have it it down 3 stops. EDIT- We found out for sure that it does!
Are you directly illuminating the subject or using it in bounce fashion?
Ok, we should have all the info now except your shorts size. The pic will help the most debug this issue.
