07-28-2009, 12:46 PM   #1
Can I run the Pentax AF-540 Flash in wireless optical slave mode ?
Hi,
I want to use my AF-540 flash in wireless mode (as slave), but trigger it from another flash, the Canon 580 II.
It works great with my built-in flash of my K200D, but doesn't respond to the Canon, even though they are both set to M (so no TTL conflicts should exist) and to the same channel.
I'm not sure, but shouldn't my AF540 fire whenever it sees another flash (like all these cheap "stupid" optical-triggers on ebay) ?
I know he can do even better (P-TTL), but why can't it also just run as a basic optically triggered flash ?
Am I missing something?
Thanks
07-28-2009, 01:22 PM - 1 Like   #2
Slave 2 mode
  1. Set the flash to wireless.
  2. Set the wireless slider to slave.
  3. Press and hold the light button until Slave 1 appears on the LCD.
  4. Press the S button to set slave 2 mode.
  5. Press the light button to exit the screen.
The flash is now in optical slave mode.
Thank you
Russell
07-28-2009, 01:34 PM   #3
Works like a charm!
Thanks!
12-10-2009, 11:16 AM   #4
Thank You!
Thank you! I needed to test a new trigger, and couldn't find my manual. Thanks!
12-12-2009, 06:54 AM   #5
Does anybody know if it's possible to do the same with the Metz 58?
af-540, canon, flash, lighting, mode, photo studio, slave, strobist
K200D: using built-in flash to trigger optical slave? cheekygeek Pentax DSLR Discussion 5 07-01-2009 09:13 PM
For Sale - Sold: Flash + optical slave kibipod Sold Items 4 04-06-2009 05:33 AM
K10D - has anyone found a way to trigger optical slave with onboard flash? Hornet Pentax DSLR Discussion 19 12-01-2008 03:27 PM
Wireless Slave flash with a K100D CRMassart Pentax DSLR Discussion 10 12-04-2007 04:57 PM
wireless trigger and slave flash ronald_durst Flashes, Lighting, and Studio 0 11-14-2007 07:04 PM
All times are GMT -7. The time now is 09:36 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
