Originally posted by Pentaxor I think you are right. if that was the case, then the only logical explanation is that the cable is incompatible for Pentax. this is possibly the reason why there are 2 cables provided for the new set. one was intended for Pentax and one was for Canon. a simple jack converter wouldn't do the trick, otherwise they could had provided a second jack instead of another cable.
Ok, there are two different types of cables for the RF-602 wireless flash triggers.
The first type is a RX->flash cable.
On one end is the proprietary connector plugging into the RX. On the other end is the
3.5mm mono connector that plugs into some flashes.
Each RX set should come with this cable, and each RX set should also come with a 3.5mm->6.5mm adaptor for use with some studio flashes with the 6.5mm socket.
If you look below, this is the content of a RX + TX set. The make up of each set is identical regardless of Nikon or Canon, and I can confirm this because I have both Nikon and Canon RX + TX sets: there is a RX, TX, booklet, RX->flash cable, 3.5mm->6.5mm adaptor and 2 AAA batteries.
The RX-only sets do not have the booklet and the TX, but is otherwise identical. That cable there is the RX->flash cable, and is the one
ShowMeTheMoney is using, with a 3.5mm->2.5mm adaptor.
On the left is a RX + TX set. The contents of the set are in the previous photo.
In the middle are RX sets. As mentioned, the only difference between the RX + TX and RX-only sets are the lack of a booklet and TX.
On the right is a shutter release cable.
The second type is a shutter release cable.
These do not come with any RX sets. You either buy them separately, or an ebay seller will add it to the bundle they are selling.
On one end is the proprietary connector plugging into the RX. On the other end is the connector that plugs into the camera. In the case of the C1 cable, this connector is a
2.5mm stereo plug. For C2, C3, N1, N2, etc cables, this end is specific to the cameras they are designed for.
In this photo, on the left is one end of the RX->flash cable. Note the 3.5mm mono plug.
On the right is one end of the C1 shutter release cable. Note the 2.5mm stereo plug. This is the one used by Pentax cameras. The stereo plug is necessary for the ground, AF and shutter contacts.
This is the other end of both plugs, the proprietary RX connector.
