I'm gonna necro this thread since I ordered some Yongnuo RF-602 wireless flash triggers. They replace my Cactus V2s units, which don't seem to sync at anything faster than 1/30th, and even then, they are not reliable, not that they have ever been. I've checked and made sure all the batteries were charged and had the required voltages, I've tried both my K10D and K-7, I've tried different channels, but the issue is still there. I got my Yongnuo RF-602 wireless flash triggers on eBay through
HK Yongnuo's eBay shop, buying a set with the Nikon transmitter (TX) and three receivers (RX). I also asked them to swap the shutter cable from one with a Nikon plug to the C1 plug that fits the K10D, K20D, K-7 and a few other cameras, which they happily did.
On the left is the wireless trigger set for Nikon. The difference between the Nikon and Canon sets is the hotshoe connector on the TX unit, see
this dpreview thread for more details (scroll down a bit). All RX units are the same. In that box is one Nikon TX unit, a CR2 battery for the TX unit, one RX unit, 2x AAAs for the RX unit, a RX->flash cord (3.5mm jack), one 3.5mm-6.35mm adapter, and the instruction booklet. The green boxes are the RX boxes, which contain one RX unit, 2x AAAs for the RX unit, a RX->flash cord (3.5mm jack) and one 3.5mm-6.35mm adapter. The last box contains the shutter connecting cable, which ends in the 2.5mm stereo jack that Pentax cameras use for the shutter release.
Now, there have been issues with getting these Yongnuo RF-602 triggers to work properly with Pentax as per earlier this thread, on the dpreview link, on flickr, etc, and after doing a series of tests, here are my results:
Out of the box:
At 1/125th, I get full sync and 100% reliability.
At 1/160th, I get a feather of the rear shutter curtain (image A), and 100% reliability.
At 1/180th, I get full sync, but only at about 60% success rate. The other 40% of the time, the RX are triggered, but there is a complete mis-sync and the flashes don't contribute to the exposure; e.g. it's pretty much a dark frame. However, the RX units are triggered 100% of the time, so reliability between TX and RX unit is 100%.
However, if I half-press and hold down the button on the TX, and then take the shot, I get full sync at 100% reliability at 1/180th.
Also, when I turn the camera off, or the camera stops metering (p114 of the K-7 manual), these two instances will set off the RX unit as well.
Taking apart the TX and removing one of the pins, the one corresponding to "SP" on a Nikon hotshoe (see above dpreview link):
At 1/180th, I'll either get a feather of the rear shutter curtain (image A), or maybe a bit more of the rear curtain (image B), but, it will trigger 100% of the time.
Once again, if I do the half-press trick, I get full sync at 100% reliability at 1/180th.
Image A:
Image B:
It appears that what is happening is that the half-press signal of the TX unit needs to be triggered to tell the RX units to get ready in order to fully sync at 1/180th. This half-press can be done though manually pressing the button on the TX, or though half pressing the shutter button on the camera, which only works about 60% of the time, since I suspect the pin I removed is shorting between ground and digital signal on the Pentax hotshoe.
Despite all this, I'm actually quite content with these triggers, and the main thing is, the results are
consistent and even though they might not sync properly, they trigger every time, something I can't say about the Cactus V2s units I had. I'll probably shoot at 1/160th and keep it in the back of my head that there'll be a slight feather at the bottom of the frame. And I guess if I
need to shoot in x-sync mode (1/180th) and need it to sync, I can always do the half-press trick.
I had originally considered getting the Phottix Atlas wireless triggers, but their price, and the fact that they have not been confirmed to be working with the Pentax system at 1/180th, made me reconsider my options.
