Originally posted by attack11: Originally posted by newarts: My camera is a K100D; when it thinks the lens is an "A" type, it pre-flashes* and uses the TTL metering system to correctly set the exposure depending on the light that gets through the lens.
Isn't the 'auto' mode I'm faking a P-TTL mode? Regardless of terminology, it works; preset the aperture on the lens, pop-up the built-in flash, shoot the photo; exposure is correct.
Dave
*I can see the pre-flash fire through the view finder. I get correct flash exposures with a manual Takumar as I change the lens' preset aperture from lowest to highest f-numbers.
no, it's not P-TTL. there's no data transfer. you're simply doing an auto TTL.
P-TTL
A pre-flash is discharged before main flash so that multi-segment metering sensor can measure the subject's distance, brightness, brightness difference, backlit condition, etc. The data obtained is incorporated to set the output of the main flash. This mode obtains more accurate results than conventional TTL mode.
But there
is data transfer from the lens to the camera. The camera has received what it thinks is proper data from the lens: ie. A type lens, Max & Min f-numbers, and a low logic state from the Data pin (ie. no MTF info & I don't know what else.)
So far as the camera knows the lens
is a KA type lens, set to the A position. The camera's user manual says it works...
Dave
When the shutter button is pressed the preflash is fired and the camera measures the light intensity with its matrix metering system, not light reflection from the sensor.
