While I've never used a p-ttl flash long enough to know its consistency... I can vouch that TTL is not necessarily the panacea people seem to think it is. Depending on the situation (i.e. in most situations) plain flash mounted thyristor sensors do just fine - and consistently so.
I have the AF280T and AF200T, and while not as accomplished as Mike, I use both in Auto on all sorts of cameras, with excellent results. Actually, I have used them in 'ttl' mode with the K100D and ZX-L - the AF280T does
not flash at full strength with the K100d, but rather goes into the Auto mode. On the ZX-L it does the TTL bit.
As with any metering system, shooting pale things close up on white foreground with dark background will fool
nearly any system, whether matrix or not, flash or not, ttl or p-ttl... there are times when one has to remember to think. Thank god for that, so our photography hasn't degenerated to a George Jetson level (push one button).
