Originally posted by skyoftexas I started out being happy with this flash, but my enthusiasm is waning. I am getting exasperated with the inconsistent exposures in pTTL mode, but this may be a problem with Pentax, and not Metz. I may have to try it in automatic to see if that helps.
Specifics about the Metz:
I handheld the flash in wireless mode, which seemed cool for fill-in, afternoon light. In fact, to some extent it seemed to work better than when mounted and in pTTL mode. However, you must learn how to use it in handheld, wireless mode or you may not get it to fire. This is because the sensor is on the left side of the flash and does not always receive the signal. I made it work by turning the flash upside down, and twisting the top a notch so the sensor was exposed.
Another issue with using the Metz in wireless is that you have to use the onboard flash to trigger it. The triggering light is suppose to be inconsequential, but it can be clearly visible in some photos. I don't know how the Pentax flash operates wirelessly.
Finally, I was wondering why some of my flash photos were slightly blurry at shutter speeds below 125, and I discovered that you lose shake reduction in wireless mode. You can imagine that holding a camera with one hand, and the flash with the other is not as stable as holding the camera with two hands. I then tried using a technique someone told me about in which you place the camera on your left shoulder and bring the flash up under the right arm as high as you can. It works, but you can't get the flash up very high from this position. This prompted me to go buy a flash cord. But the Metz does not do pTTL with the cord. It has one more pin than the cord, and Metz does not make a flash cord for it.
Since I like to shoot for ambient light - f5.6 @ 60, or lower, I was prompted to mount the flash back on the camera, but, as I mentioned above, I have been very unhappy with the consistency of the exposures. I don't know who to blame for these results, Pentax, the flash, or me. I intend to figure this out because it is very difficult to shoot weddings with unreliable flash exposures.
In summation, the Metz does not provide for the most desirable off camera, hand held usage. It has not been performing well (consistently) mounted to my camera (K20D), although I'm not sure who or what is at fault. A little niggle. The battery door is flimsy and I have had to replace it. (It only cost $4, plus $6 for shipping, but it's an indication of the quality of workmanship.)
I guess I'm hoping the rumors of a new Pentax flash are true because I'm not sure where to go with this.
Michael
I need to correct a few things here. Maybe it'll help.
It sounds like you're saying that triggering the Metz with the onboard flash is a bad thing. All major camera brands' wireless triggering is done that way. The 540 and Sigma 530 Super do also. If you're using radio transmitters like Skyports, Radiopoppers, etc that's a whole other ball of wax. The flash sends the info to the metz (or 540, doesnt matter) about how bright to pop your flash. Make sure that your K20 is set to wireless mode. If you don't then the onboard flash will be your main exposure. Even in wireless mode the flash can be picked up a bit in pictures but should be negligible. The only exception I've seen is if you're in a room with alot of metal or mirrors. Then you're seeing the reflection of the trigger flash that was sent a split second before the shutter opened.
The flash cord should do fine. I'm using the Adorama P-TTL cord when I use my cam on a bracket and it's just like putting the flash on the hot shoe. Are you sure you have the setting on the Metz on P-TTL? I figure you're not needing it on P-TTL HSS since you say you like to keep the shutter at 1/60 or less.
The Metz 58 is a great flash and the Pentax 540 is a close second. I have them as well as the metz 48, a Sigma 530 Super and an AF-360 that I most use as either a kicker light or to replace the onboard flash if I want a stronger trigger flash. When it comes to the battery door, I don't think there's anything more "niggly' than the 540! I hate replacing batteries when I'm cold or have allergies! Ahhh-CHOO! SNAP!!
