Originally posted by Bear
you see, my bracket isn't as high tech as yous guys. Its a Custom bracket Folding S...Im trying to learn how to properly use a flash. Ive started to read the same about what you do Aloha, with setting everything to manual. I know for me, it takes a couple minutes to get everything right, but im sure the more I do it, the faster ill be. Is there anyway for me to "upgrade" my bracket by adding a rotator or is my only option from this one is to find another bracket with rotator built in? I really like the idea of keeping the flash horizontal and not vertical. Does it make any difference if the flash does end up vertical but still centered above camera on a bracket? thanks guys!
In terms of flash mode setting, for now, let's just use p-TTL. The nice thing about p-TTL is that in general, the flash and the camera take care of the exposure so you can concentrate on other things.
For events, because there is little time to think and change the camera and flash settings, I normally use high ISO (400 or 800), and if at all possible, larger aperture (minimal F/5.6, mostly F/8 or F/11) for DOF. I also set shutter speed as low as possible (1/30 or 1/60). These settings allow as much ambient light as possible, resulting in better photos and shorter flash cycle time.
Most of the time I use a Metz 54MZ-4 or a Pentax 540, either with a Sto-fen and tilt up 45 or 60 degrees, unless when I need to reach far, the flash head will be straight forward with no diffuser.
I can see a few challenges with the Pentax 360:
1. It's not that powerful. A diffuser robs about 2 stops of light. You can set high ISO (800, 1000) to work around this, and deal with noise later in post processing.
2. The head does not swivel. In landscape format, you can tilt the head up, but in portrait format, with the limitation of the Folding S bracket, you have to shoot with the head straight forward. (that answers your question, " Does it make any difference if the flash does end up vertical but still centered above camera on a bracket?" - It makes a difference only when you want to tilt the flash head up).
I don't think trying to bounce the flash is a good idea. Most of the time, you don't have a good surface to bounce the flash against.
