Originally posted by raider Does it help if I also have a Metz 48 flash? What wireless trigger is recommended then?
The Metz 48 AF-1, the Metz 54 AF-1, and the Pentax 540FGZ are the only P-TTL flashes I know of that have the ability to disable auto power off feature. If you are looking for a flash to do P-TTL and allow use with a remote trigger then one of these will work. If you already have another P-TTL flash, then buying an older used flash or a new manual flash to use with radio triggers is also a perfectly valid option.
There are a number of wireless flash trigger systems. Recommending one is pretty tricky as it depends on the features, range, reliability, and price you want to pay. It probably would be a good idea spend some time at the
Strobist site reading all that is there on the different trigger systems to help understand the difference between them.
Thank you
Russell
