Originally posted by gsrokmix
Thanks for the reply. I'll start with those settings & see what I get!
George
The Vivitar 285HV is a great flash to use in manual mode. Experiment with the color tabs on the mode dial of the flash. The calculator will help. Experiment with different ISOs. But always remember to use 1/180 or below or it won't fire. You may not be able to get 1/180 in Manual mode; more like 1/160. However you will ALWAYS be set to 1/180 in the X mode and all you have to do is change your aputere on the camera. The flash is great for bouncing as well.
