11-26-2009, 09:39 PM   #1
Class A's Avatar
Manual power levels with an Auto Flash
Auto flashes are handy when used on their own. They use a thyristor to shut off the flash once the exposure has been deemed sufficient by the flash.
When using multiple flashes in conjunction, however, it is best to set their power levels manually, i.e., not let the flash decide which output level to use.
Many Auto flashes do not allow the setting of the power level but here's a trick to get at least one manual level:
If one blinds the photo diode with which the flash measures the exposure (say with a opaque tape), the flash will always go full power with respect to a particular setting. Depending on the level chosen, this will result in a consistent flash output, corresponding to a manual power setting.
Example:
The Vivitar 2500 has four settings:
  • M (manual) = full power
  • blue (auto setting 1) = up to full power
  • red (auto setting 2) = up to ~1/3 power
  • triangle (autowinder mode) = 1/8 power
So with this flash one can achieve three output levels: full, ~1/3 (requires blinding of the photo diode), and 1/8.
I suspect that one of the auto setting of an auto flash will always go up to full power. I wouldn't make sense if the flash weren't trying to give "its best".
P.S.: When using older flashes, always make sure that their trigger voltage is not too high when using them on-camera.
11-26-2009, 09:57 PM   #2
I've copied this thread into the articles section as requested. Please add any future improvements here: https://www.pentaxforums.com/forums/photography-articles/81497-manual-power-l...uto-flash.html
Feel free to continue discussion here as needed.
auto, exposure, flash, flashes, level, levels, lighting, output, photo studio, power, power levels, strobist
Manual power levels with an Auto Flash Class A Photography Articles 1 11-27-2009 12:29 PM
Auto power shut down on the AF 360FGZ Russell-Evans Pentax Camera and Field Accessories 4 06-26-2009 01:05 AM
For Sale - Sold: Multiple Auto (Digital & Film) and Manual Lenses, flash + more jjdgti Sold Items 18 10-03-2008 09:30 AM
540FGZ & auto power off Groundloop Pentax Camera and Field Accessories 4 05-28-2008 11:29 PM
Optio W10 and Auto-Levels betsypdx Pentax Compact Cameras 0 08-29-2007 11:06 PM
All times are GMT -7. The time now is 12:30 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
