11-27-2009, 03:46 PM   #1
LeDave's Avatar
Metz 48 AF-1 problem.
When I shoot my Metz 48 AF-1 w/ Sto-Fen Omnibounce diffuser on my K-7 in P TTL settings, the lighting is always a bit too bright, I always need to set it down to like -0.7 or -1.0 in EV stops just to get the photos to look more natural. Anybody else have this problem?
11-27-2009, 09:46 PM   #2
mattdm's Avatar
QuoteOriginally posted by LeDave Quote
How are you using the diffuser? Flash head at 75?
11-27-2009, 11:19 PM   #3
LeDave's Avatar
QuoteOriginally posted by mattdm Quote
That's probably where I'm going wrong, thanks. Will try again.
11-28-2009, 06:55 PM   #4
mattdm's Avatar
I've found it to still be a lot more random than when using P-TTL bounced (ceiling, usually), where it's mostly dead-on. I haven't actually used it enough undiffused and straight-ahead, but my impression is that with the diffuser is on, P-TTL is even _more_ hard to control than that. It's not _random_ for a particular scene, but seems incredibly influenced by the degree of reflectivity in the field of view.
11-29-2009, 04:53 PM   #5
Arpe's Avatar
I was under the impression that 45 was the more common angle to use?
11-29-2009, 08:18 PM   #6
mattdm's Avatar
QuoteOriginally posted by Arpe Quote
The suggestion on the printout that came with mine was to use 45 for film cameras and 75 with digital presumably P-TTL vs. TTL being the difference. Anyway, the more-upright direction does seem to work best with mine, although as noted it's still pretty sporadic.
(That said, I'm still happy with the product: when there's no convenient ceiling and no way to use off-camera flash, it's way better than straight-on flash, and infinitely better than no photo at all.)
11-30-2009, 04:52 PM   #7
Arpe's Avatar
So you use it at 75 even when not bouncing? Presumably with the little white thing up?
12-01-2009, 06:40 PM   #8
mattdm's Avatar
With the Sto-Fen diffuser, which works somewhat better than the bounce card for this purpose. (The bounce card is fine for what it's meant for, but not so good for this not enough light goes forward. In fact, I tried that, before breaking down and buying the Sto-Fen, which is a lot of money for a little piece of molded plastic.)
This room (in the Boston Children's Museum) is very dimly lit and has high ceilings (which are painted black, to make things even worse). (Sorry, the image is a little oversharpened after downsizing for posting as an attachment.)
PENTAX K-7  Photo
12-02-2009, 05:28 AM   #9
KJon's Avatar
Matt, nice shot under difficult circumstances. I was wondering if you used any EV comp in this shot? I just finished a shoot (w/ Metz 58, Stofen Omni Bounce), K10D, aperture priority, ISO 400. 75 degree tilt and P-TTL and a really high blond wood finish ceiling. Test exposures on the LCD looked great so I didn't add any EV comp. Subsequent viewing on computer (and a few prints) ended up looking a little dark. That being said, subjects were all exposed correctly.
Still trying to wrap my head around the flash thing <g>. Any additional thoughts would be appreciated.
Best,
Kevin
12-02-2009, 05:32 PM   #10
Arpe's Avatar
Hmmm. I'll have to try the 45 v 75 thing. Thanks.
af-1, flash, lighting, metz, metz 48 af-1, photo studio, strobist
METZ 48 - K10 Problem tiily_p Flashes, Lighting, and Studio 3 06-26-2011 11:32 PM
K-x with new metz 58 AF-1 wireless problem shawnrnicholas Flashes, Lighting, and Studio 5 10-29-2010 01:16 PM
Possible problem with Metz 48 mindglow Flashes, Lighting, and Studio 1 10-27-2010 07:52 PM
Any else had this problem with the Metz 48 Ben Hunt Flashes, Lighting, and Studio 9 04-29-2010 07:54 PM
K7 with Metz 58AF1 WL - Problem sixstring Flashes, Lighting, and Studio 1 12-02-2009 05:33 PM
All times are GMT -7. The time now is 10:36 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
