12-03-2009, 03:31 PM   #1
Metz 58 AF-1 (Pentax) firmware upgrade
I have just heard back from Metz who have confirmed that a firmware upgrade version 1.1 is due for release this month. I don't have any details as to what will be included just that there will be improvements. Hope this helps any other Metz users. We finally get to put the usb socket to work.
12-03-2009, 04:37 PM   #2
Ari
Ari's Avatar
I really hope that's true.......
12-03-2009, 05:21 PM   #3
QuoteOriginally posted by Gregpen Quote
Thanks for mentioning this!
12-07-2009, 04:12 PM   #4
More info on the firmware
The following improvements will be included in the new firmware version 1.1 for the flash unit mecablitz 58 AF-1 digital for Pentax:
1. Operation of second reflector in E-TTL mode enhanced.
2. Start signal in remote master mode changed from second reflector to main reflector.
3. Setting of the parameter values by repeat key.
12-07-2009, 04:57 PM   #5
Arpe's Avatar
Wonder if they'll do anythnig for the 48?
12-08-2009, 01:16 PM   #6
date
any info about relase date?
12-30-2009, 09:57 PM   #7
mattdm's Avatar
Firmware Updates out now.
mecablitz 58 AF-1 digital: Metz
mecablitz 48 AF-1 digital: Metz
In addition to the improvements for the 58 mentioned in Gregpen's post, the 48 gets:
1. Flash range indication enhanced.
2. Test flash with partial light output level.
12-31-2009, 04:47 AM   #8
LeDave's Avatar
My Metz that I bought new a couple of months ago never came with a USB cord, you have to buy it seperately correct?
12-31-2009, 05:27 AM   #9
emr
Guest
Thanks for the mention - I hadn't noticed the upgrade for my 48.
The USB cable is just a standard one, use any normal one that has the miniconnector at one end.
01-01-2010, 02:41 AM   #10
apemen's Avatar
Metz 58 still don't have wireless manual mode use, am i correct?
01-01-2010, 12:39 PM   #11
Hi All,
Just now updated it to 1.1 as per the instructions, is there a way to check It?
Thanks
Kriss
01-01-2010, 08:38 PM   #12
Hopefully, the Metz 48 could do wireless manual mode after the firmware upgrade....
QuoteOriginally posted by mattdm Quote
01-01-2010, 08:40 PM   #13
mattdm's Avatar
QuoteOriginally posted by sbbtim Quote
It's not on the list, so I kind of doubt it.
01-01-2010, 08:45 PM   #14
The second improvement makes it promising.
With the old firmware, Metz 48 can only do 100% output in wireless manual mode.
The mechanism should be the same. The diff is only in how the flash is triggered, either by the "test" button or by the trigger flash.
Edit: My Metz 48 AF-1 is not around. Otherwise, I would give it a try.
01-01-2010, 10:03 PM   #15
Closed Account
enoxatnep's Avatar
Mac users??
I guess there must be no Metz 48 owners who use a Mac since I the firmware update is only an .exe file for Windows.
firmware, flash, lighting, metz, metz 58 af-1, photo studio, strobist
Firmware upgrade for Metz 48 flash Gerrys Troubleshooting and Beginner Help 3 05-03-2012 07:30 AM
Trying to upgrade firmware on pentax k100D Lisad620 Pentax DSLR Discussion 9 03-31-2010 10:29 AM
Pentax K7 Firmware upgrade 1.2.016 jfalcon7 Pentax DSLR Discussion 0 02-14-2010 06:48 PM
Why no firmware update from Metz for Pentax? quaker Flashes, Lighting, and Studio 4 11-09-2009 02:43 PM
How to Upgrade Firmware? rzarbo Pentax DSLR Discussion 13 01-25-2008 04:19 PM
All times are GMT -7. The time now is 04:27 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
