Originally posted by sterretje I know it's fantastic unit
I used it with my Minolta X700.
I bought myself a hotshoe-to-PC adaptor and that works (I have a safe serial number). My current problem is the focussing in low light situations and therefore I like an IR assist as is nowadays available in flashes.
I saw your comments in the thread that you have mentioned. As far as I know there has never been a SCA adaptor available (PC cord only). Further the flash came standard with an 28mm attachment.
I'm not giving up on the 45CT1; it might do a job as a remotely triggered flash in future.
Unfortunately that's true, the old CT-1 model can not use SCA adapters and thus cannot also not use the AF illuminator, which you can use with later 45 series flashes.
My own experience is as follows: I do about 90% of my flash shooting (and I use flash very often for shadow fill-in etc.) is done with a hot shoe flash gun (Metz 54-3/4). My hammerhead flashes (Metz 45-CT4 and 50something) will mainly be used for weddings, where I need loads of power. In this case I often use them as a remote background light, triggered by the on-camera Metz.
P-TTL is not really necessary. A good Auto-mode flash gun will give results as good or even better (aka more consistent). For those cases, where neither P-TTL nor Auto works, I use manual power output and set the aperture as needed.
I have two flash brackets, but I rarely use those. A large hot shoe flash gun will be far over the lens to give a good general light. The only problem might be portrait orientation, when the flash reflector is sideways from the lens, That can give very unnatural shadows. In that case I try to use bounce flash and will add a little fill with the Metz's secondary reflector. My last wedding was shot only with such a set-up and the images came out nicely, without any strange flash-induced shadows.
Ben
