01-24-2010, 12:01 PM   #16
QuoteOriginally posted by ryan s Quote
Reverse polarity = most flashes use the bottom, center pin as the +, and the little metal pieces inside the "shoe slot" are the ground. Some are the opposite and use the center pin as ground.
And on this issue, I'll say...come on people. I know old flashes are cheap/free...either sell them and buy one of the boatloads of good flashes for under $100 (Nikon SB series...love my 24)...buy a Safe Sync...buy a hotshoe -> PC adapter...buy a wireless flash solution...something.
Don't risk a mutli-hundred dollar camera with a free flash. The worst that could happen is you kiss your flash circuits goodbye, and we'll probably laugh and say "told you so." Wait...that's not very good
I think your suggestion is appropriate for majority of the people out there. But for the sake of the new camera users who do not know any better and just happen to have one of those old flashes sitting around and for the sake of the real tinkerers who like to do weird and creative things with their old flashes, Pentax should publish the maximum trigger voltage and current and write a clear caution statement regarding older flash in the manual. This should actually help them sell more cameras to those tinkerers and prevent, to a certain degree, the uninformed newbies from blowing up their camera.
Note: I think most hotshoe to PC adapter may not provide high voltage protection. If your camera has a build-in PC port, then the PC port is protected from "high" voltage. But this protection does not extend to its hotshoe.
01-25-2010, 01:13 PM   #17
ryan s's Avatar
QuoteOriginally posted by ma318 Quote
They should do that, although I bet they'll get people saying "the manual said xxx, and mine was xxx...but something's wrong"
Then you get into variances of multimeters and all that. For example, my "average" meter that most folks have doesn't show an absolute 0 reading for impedance...more like 1.5 Ohms. I'd have to wonder how far it's off once the voltage starts going to 400+.
I have no idea if the hotshoe -> PC provides a safe connection...it's been a while since I read about them, and I use wireless triggers anyway.
01-25-2010, 01:37 PM   #18
The reality is that without the maximum voltage stated in the manual anything, other than a Pentax flash, mounted on the hotshoe is "potentially" not safe. The radio triggers are definitely "safer" but without the the voltage stated in the manual, Pentax does not have to fix any damage unless you are using a Pentax flash.
01-25-2010, 03:14 PM   #19
Pentax is ISO 10330:2002 compliant. That sets a 25 volt standard on the flash voltage.
If you think printing anything in the manual would help, I doubt it. You know how many times folks have to be told RTFM?
Good tinkers would check out the info before doing anything possibly bad for the camera.
Any Pentax flash will work. And all the new top 3rd party flashes will work if marked for Pentax. Other than that, you have to play on your own dime.
01-25-2010, 03:42 PM   #20
Wildlifephotog, you sound like you know what you talking about. That's good enough for me. Thanks for the info.
01-25-2010, 04:22 PM   #21
The manual states to use a Pentax flash with my Pentax camera ... would that include the Pentax Takumar AF14 Flash, from twenty some odd years ago?
I've got one coming in the mail, for basically the cost of shipping. I'll be testing it with a multimeter before mounting it up.
01-25-2010, 04:49 PM   #22
I don't have such a flash so I don't know for sure. Maybe someone who has one will let you know.
If you are following the instructions exactly in your manual then you should be in good shape.
Since it is a used flash and you don't really know the condition it is in, you should always put a fresh set of new batteries in and check its trigger voltage to make sure it is safe. It is a very easy thing to do. That will give you the peace of mind.
01-25-2010, 08:24 PM   #23
ryan s's Avatar
QuoteOriginally posted by justDIY Quote
I had an AF16 (pretty sure it was) and it tested low. Definitely check yours out before mounting since it's not listed here Photo Strobe Trigger Voltages
11-22-2013, 07:14 AM   #24
What is considered "high" voltage? I have a Vivitar Auto Thyristor 225 that I use on my Q, and it has a 35v trigger voltage.
Charles.
11-22-2013, 09:11 AM   #25
QuoteOriginally posted by ChopperCharles Quote
Charles.
That's too high from what I've read. 24 volts is considered the maximum "safe" voltage for any Pentax DSLR, and personally, I like to stick to 12 volts or less just to be on the safe side. I'm not sure if the Q is the same as their DSLRs, but I'd guess it probably is. I'd stop using that flash immediately, or buy a Wein Safe Sync if you really want to keep using it.
I use Sunpak 422D flashes with my Pentax K-x bodies and the Q. It's a great and cheap flash unit with a trigger voltage of around 6 volts.
12-30-2014, 11:51 PM   #26
LXNights's Avatar
I have a Vivitar 285 and Sunpak 622. DO you think those are safe to use with current Pentax cameras like the K-7, K-5, K-50, K-30, K-3, etc.?
12-31-2014, 03:54 AM   #27
QuoteOriginally posted by LXNights Quote
The only sure way to know is to check the trigger voltage. Buy or borrow a digital multimeter (you can buy one for under $10), then do a google search for how to check the trigger voltage. It's pretty easy, and will give you peace of mind.
12-31-2014, 04:37 AM   #28
LXNights:
The 622 is safe. The 285 is not.
The 285 is 350 volts and the 285HV is 12 volts.
The damage probably won't happen on the first use. It will likely happen from continued use and that is what destroys the electrical components.
Using old high voltage flashes is false economy. They were built and used when actual metal contacts handled the voltage in the camera. The components used in modern electronic cameras are not designed for those voltages. No manufacturer designs in a 10 to one safety factor.
12-31-2014, 07:57 AM   #29
Not a Number's Avatar
QuoteOriginally posted by wildlifephotog Quote
It depends on the 285. It is only the very early manufactured units that have 350 volt trigger voltages. The Vivitar 285 that I bought new in 1982-83 measures out at 5.36 volts maximum with fully charged NiMH batteries.
12-31-2014, 09:42 AM   #30
I was going by what Vivitar themselves said, as was quoted on Photo trigger voltages.
"Alan Latafat Correa checked with Vivitar and they clarified:
The 285HV has a voltage of 12V. The 285 has a voltage of 350V."
answer, camera, fire, flash, flash trigger voltage, lighting, pentax, photo studio, regulator, strobist, trigger, voltage
Flash Trigger Voltage Known to Work Class A Flashes, Lighting, and Studio 26 04-27-2023 10:11 AM
K7 - Max external flash hotshoe trigger voltage mppuser Pentax DSLR Discussion 1 08-14-2010 09:14 AM
Flash trigger voltage and how it relates to radio triggers joshnl Flashes, Lighting, and Studio 7 07-28-2010 04:01 PM
Flash Trigger Voltage Testing Question Mike Cash Flashes, Lighting, and Studio 13 08-18-2007 10:05 PM
External Flash Trigger voltage for the ... roscot Pentax DSLR Discussion 3 07-27-2007 12:06 PM
All times are GMT -7. The time now is 07:05 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
