Originally posted by jedcrocker I had also been looking recently for an AF assist lamp solution for my K200d.
I ended up getting a Pentax AF-330 flash from KEH for $27. This is a TTL flash (not P-TTL) so needs to be in manual mode if you use the flash, but I did confirm the "spot beam only" AF assist lamp works on the K200d. In low light, the red lamp (grid pattern) illuminates the subject. I can now focus in near darkness. This mode works without firing the flash.
The AF-240 also has a spotbeam AF assist mode and I think it is nearly the same vintage as the AF-330, so it may work as well.
I hope this helps
Hey, not too bad. Does the manual mode only work in full power, though, or can you turn it down? (I'd be pretty happy to settle for something from the film era that offers the AF assist light and a couple old-fashioned auto apertures. I do actually expect to be fairly-often carrying film cameras alongside my K20d. It'd be nice if it worked adequately for both. (And old fashioned 'auto' flash is something I'm quite facile with: I just learn what it's trying to do and set exposure on the camera manually: I'm really slow with guide number calculations, these days, particularly when I'm tired, so full manual isn't the first choice for a lot of these applications: still, low power could come in handy. )
To think I at least used to be so familiar with my old 285HV that I could generally just visualize. I don't think I'd count on that ability after all this time, though.
I'll tell you, though, I knew Pentax's decision to leave out the AF assist light on the K20d would complicate my life a fair bit, but sometimes you just want to fire up the Wayback machine to go back to when they made that decision.
