Originally posted by LeDave I think it's because it's not sync'd properly. Your shutter is closing too fast causing light to cut off from the sensor before it reaches the bottom area. It's a user or camera/flash fault, not the receiver or trigger.
Yeah,.. As I wrote in my message; I know that camera did not sync properly with the flash, and I’m aware that rear curtain is covering the sensor so fast that that portion of the sensor does not get properly exposed with the flash. I am puzzled why my sync speed is lower with radio triggers compared to when I trigger 360FGZ optically.
Originally posted by kenyee replace the battery in the transmitter...
Hmm,.. Might try that.
Originally posted by BBear I have the same setup, actually a collection of (6) 285's and cactus, which I still have but I upgraded to Cybersyncs...
And the thing is, the cactus are very cheap, economically as well as lack of quality.
I dont think the problem is the flashes, because I can use the same flashes with the cybersync at 1/180.
One "trick" you can do with the cactus, is using 1/3 EVs and set the shutter to 1/160, so its a bit faster than 1/125. I never had problems with 1/160 with the cactus, but had the same issue with 1/180.
Great info! Thanks!.. Cybersync system looks very nice, but it is going to blow my budget!
Sorry, beginners question; how do I get my shutter to 1/160? My shutter goes in these steps: 1/125, 1/180, 1/250,... I don’t think I get 1/160. Are there some sttings I need to do to get that?
Originally posted by GeneV I don't have that problem with the CTR 301p either controlling a case full of Vivitar 283s. I think that, among the inexpensive triggers, the 301 is the better choice. Of course, I'm sure Cybersincs would be even better, but not so inexpensive.
Thanks for the suggestion. I am actually now considering CTR 301p system as the receivers have that hot shoe adapter.. so I do not need to mess about with cables. Cool!
Originally posted by wlachan Any radio slave sync will introduce certain delay because they needed to "talk" with each other. This delay, when added with the flash sync, the max sync speed will be decreased. Some radio slaves have shorter delay, some longer. For instance, the same Metz 40MZ-3i I have can do 1/160s with Microsync on the DS, but the same flash can do 1/180s with Skyport, which again delays the max sync speed of 40D from 1/250s to 1/200s.
That’s what I was thinking too,.. feel bad for some Canon/Nikon guys who have to step down to 1/160 or less from possible 1/320 sync speeds they could get with Pocket Wizards.
