Originally posted by Jewelltrail Yes, I'll mostly be doing Macro work, with the a lens' filter size of 55mm. It sounds like the 8r would be okay for this then--thank you. Of course, I would not rule out use of the ring flash for shooting people indoors, lowlight. But, from what I am learning here, satisfying both of these needs, in one ring flash, may be too much to ask--is that correct guys?
Thanks Dave!
Typically macro ringflashes simply do not have enough output for portrait work. The DX-12R can be used up to 2m distance, as could be some more recent modells. It looks as whether nowadays ringflashes have a higher guide numbrt, than they used to have in the past on average. For portraits, though they can only be used as fill-flash and won't provide the typical ringflash look, which is often used in fashion photography. The macro ringflashs simply have too small a diameter to achieve that and even GN 12 is far too less.
It would perhaps be worth the investment, to buy one of those ringflash attachments for portraits, which slip over an existing hot shoe flash. It needen't be the expensive Rayflash, there are some cheap Chinese knock-offs.
But for macro these things are too big and bulky in my opinion. For instance, I used the DX-12R to follow the breading of our "house" blackbirds, which were nesting in a bush just at the edge of our terrace. With the macro ringflash I could take images through a small opening in the otherwise dense bush. With a hot shoe flash and those ringflash attachments, I would heve needed to cut away a lot of branches and that would have disturbed the birds very much.
Ben
