Originally posted by C.W Tsorotes Cool I was curious.
How do people manage doing high speed photography, I seen it done with the K20. Ie capturing a balloon bursting, etc.
In a dark room, ambient does not contribute to the exposure, only the flash.
The flash burst itself is very short, and independent of mechanical shutter speed. Usually for these shots, the basic process is:
1) Darken room as much as possible
2) Open shutter in bulb mode
3) Trigger whatever event you're trying to capture
4) Flash triggers in response to the event. There are multiple ways of doing this, all need extra electronics. Some people use acoustic triggers (flash pops on loud noise), some use optical beam breakers, there are other options.
5) Close shutter
The key here is that in a dark room, there is no ambient exposure even when the shutter is in bulb mode.
Sync speed, as described here, is the fastest shutter speed at which the shutter is fully open for a period of time. (At faster speeds it becomes a "traveling slit"). A strobe popped when a focal plane shutter is in "traveling slit" mode will only illuminate part of the frame. So mechanical sync speed is a limitation when you are trying to balance flash with ambient (usually in bright daylight, for the purposes of the flash overpowering daylight).
High speed sync will take the flash and pop it multiple times rapidly, causing what is effectively a continuous light for the duration of the shutter. This gives even illumination across the frame at high shutter speeds, but once you enter HSS, the general rule for flash exposure being independent of shutter speed no longer holds true.
You can implement "ghetto HSS" by putting an ND filter on your lens. It has the same basic effect. (See above - HSS begins to be affected by shutter speed once you exceed the camera's sync speed. An ND filter filters the flash, but allows you to increase the shutter speed past sync speed.)
These days, unless you need portability, an ND filter + extra-powerful strobe (like the Adorama FP620M monobloc + battery pack) will be cheaper than an HSS-capable flash and allow the same results in most situations.
