You could trigger the LumoPro with a PC sync cord, or use the optical trigger, or a radio trigger.
By the way, I would go with the LumoPro all the way. You get swivel, built-in optical slave, and a 1/8 power setting. The Vivitar lacks all these.
As far as triggers go, I get the impression you're not sure of what we're talking about.
An optical slave, which the LumoPro has built-in, will fire the flash as soon as it sees another flash fire. This is by far the cheapest and easiest method of firing a flash without wires. But its range is limited, it doesn't work in strong sunlight, and if anyone else around you fires a flash, it will trigger your slave as well.
I HIGHLY recommend the Cactus V4 radio triggers. They are light years ahead of the V2s. With these, there is a transmitter mounted on your camera, and each flash gets a receiver. The standard TX/RX combo is $40. I spent $100 to get 1xTX/3xRX from
www.gadgetinfinity.com. But that may be out of your budget, in which case optical is the way to go.
EDIT:
Actually, after re-reading your original post more carefully, I see that you already have a Promaster flash. You can indeed use that off-camera with a set of the Cactus radio triggers.
