For the life of me I can't find an answer to this anywhere on the internet or in the manual, and a search of these forums turns up no results that are relevant to this either.
When I have the thing mounted to my camera, the LCD says that it has a range of about 12 feet at f/4 and ISO 100. This changes a little bit depending on the focal length I'm using on my lens, but it's always indicated to be somewhere around 12 feet.
Now the guide number of the Metz 48 is 48 meters, which is about 158 feet as ISO 100. I recently learned how to do Manual flash because of all the complaints I heard about P-TTL and exposure, so I know that to calculate range in full manual, you do the following equations.
Guide number/distance = f/stop
So lets say my subject is 12 feet away. Using that equation (158/12 = 13.17) means I should use an f/stop between f/11 and f/16. As mentioned above, the LCD indicates that this distance of 12 feet is the maximum effective distance when I have f/4 set. This is a huge discrepancy between the two.
So what's going on with my flash? I upgraded to the latest firmware for the flash the other day, and never noticed this problem until then, but at the same time, I never knew anything about manual flash until right before I upgraded, so I don't know if the firmware screwed it up or not.
Any help would be much appreciated
