Originally posted by smcook99 Thanks Daz,
Can you clarify these two points a little more.
Topic 1) Why, if I get a perfectly exposed shot at ISO400 (forced) does the camera select ISO1600 in auto (If I let it go that high)? Why isn't the camera (said to under-expose) happy with a lower ISO?
Automatic systems are a wonderful thing. They try to take care of all of these perimeters for you so you can concentrate on other things. The problem is they end up hiding where the edge of the system is until you are on the wrong side. Think a car going down an icy road with all wheel drive, traction control and antilock brakes. When you end up upside down in the ditch going around a curve what happened? You don’t know how fast you should have taken the curve all you know is how fast you were going is not it. With out know all the settings I am guessing a little here. In my experience with the K20D it picks some parameters over some others and that it will add flash the last of all. So with that in mind it will try to use ambient light first. It will increase ISO to the max you let it and then look to flash. At ISO of 1600 it should have not needed much if any flash and it probably commanded the flash to minimum power. As you decrease the ISO you get to the point where the system needs to add flash but now there is not enough ambient light and system is biased against add to much flash so it under exposes.
Originally posted by smcook99 Topic 2) You said the Flash setting in the camera is a "weak per photo flash", do avoid sounding stupid at the obvious that I know the camera flash is per photo, I'll make the assumption you are referring to the pre-flash that it uses to meter the scene. Going on that logic, are you saying if I increase that value than the pre-flash is brighter? And if the pre-flash was brighter wouldn't the camera think the scene is brighter and use a weaker exposure flash? When I increased that value in the camera the photo was brighter not darker. So I have to assume what I witnessed was accurate and not the assumption I just made. If what I witnessed is the correct of the two logic, than when do I use the Flash Output control on the flash and when do I use the camera flash output setting?
Yes pre not per. I apologize about the typo. In my defenses I was trying to get it out so I could go to bed.
AFAIK the power out in the pre flash is the same (although different flash units may have different outputs) no matter what the settings are. This is a weakness in this type of system. It only gets one bite at the apple. When you change the cameras flash bias it is just that. Biasing what the camera thinks it needs for flash.
The EV bias is what the over all the camera thinks there is from the meter before the pre flash and the flash power out is what ever you tell the camera to bias it this way. Now if you think about the process you can see how this would work. If you tell the camera to change the EV of the metering, as it is darker then it thinks it is then it could try to up the ISO. This means that it may not add much light from the flash. If you leave the EV but bias the flash +- then only what flash it thinks is needed will be changed. This kind of control allows you to balance the ambient to the flash. This will give a better looking photo. How to do this takes some experience and practice.
The K20D to me is like a teenager, it works better when it is given some limits. So telling it more what you want it to do give better results.
What it looks to me you are trying to do is just see how much light the 360 can put out not how the over all system works (at least at this time, the system can come later). To do that you have to bound your unbounded variables and eliminate as best you can any variables you can’t control. To do that I suggest you try the following experiment. This is a brick wall type photo not how to get a good photo.
Set the camera to X mode. This will lock the shutter speed to 1/180 and get rid of as much ambient light as you can. Usually you would want to balance the ambient to the flash but this is brick wall stuff. Set the ISO to 100 and the aperture of the lens as fast (small numbers) as it will go. On the flash set it to manual full power out. If you are using direct flash set the flash zoom the about the same as the lens. You don’t want to waste power off to the sides.
Take a photo. If it is too dark (not likely unless the room is really big) add ISO until you get what you want. The difference is how much more flash power you need. If it is too bright (more likely) then decrease the power out of the flash. This difference is how much flash power reserve you have or power you need.
But a more practical test is turn the flash off. Set the camera to take the photo you want getting as close as you can (with out going over 1/180) with out the flash. You may have to set the setting in manual in the camera. Next add the flash in manual keeping camera settings the same. Add flash power until you get the photo you want balance the ambient to the flash. Less flash is usually the better side to be on. Look and see how much power the camera has left to give you. This will let you know more what you can do.
DAZ
