That was a FANTASTIC reply and answered a question I was about to ask.
I just got back from the playground where I gave it a good run through with my son. Ev up, Ev down, camera bias up, camera bias down, flash out up and down, HSS, max flash sync, measuring fill flash distance limit, the works. I was about to come back and say that in half of my shots I had to actually dial back the flash output 1 to 1.5 or dial back the Ev 1.5 because they were over exposing. This, however I'm guessing now is because I was fixed at ISO 100 (it was broad daylight after all). Now after reading your post I'm thinking that maybe the shots were starting to bleach because I should have let the ISO rise instead of using too much flash. I always had the logic that the lower the ISO the cleaner the photo so on bright days I always fix at 100. Maybe I should have used auto with a max of 200 or 400?
I was then going to go on to say that chasing a kid, fixing a focus point, adjusting the exposure and quick tuning focusing, I don't know how anyone handles fast changing scenes and uses a fill flash and manual lens, let alone just a fill flash. I was having to decrease or reset the Ev everyone other shot, and God forbit he turns me into the sun, then I have to slam the HSS switch over and crank up the Ev! In hind sight, perhaps if I let the camera increase the ISO where it wanted, then it wouldn't have over done the fill flash and I wouldn't have had to waste seconds adjusting every twist and turn?
And..... what would a reply from me be without extending it by injecting another question!? LOL. I was under the impression 'M' on my k20d was a handicapped Manual, in that I control Shutter, Aperture, Iso. I didn't realize I have to manually control the Flash in that mode. Am I correct now in thinking with M the camera doesn't control the flash? And if so, should I put the Flash in Auto mode?
Thanks again!
