04-08-2010, 07:03 AM   #1
flash AF200T and 160 on DSLR?
hi
can i use my old 200T & 160SA pentax flashes on my K100D?
04-08-2010, 07:51 AM   #2
Moderator Emeritus
Yes they will work fine in manual mode only. You will not have camera metering to adjust the flash output and since neither of these flashes have adjustable settings for manual, You will have to do a little guessing on exposures. But they are safe and will work.
This thread is being moved to the correct forum. Thanks.
04-08-2010, 10:49 AM   #3
Nesster's Avatar
I use the AF200T in auto mode with no problems, and if the 160 also has such, you can do so with it as well. All you give up is TTL flash, or rather pTTL. The sensor on the flash itself measures the light. The camera will even set itself to the correct aperture and shutter speed (though you can check that for yourself) so you don't even have to do that part manually.
04-08-2010, 11:23 AM   #4
QuoteOriginally posted by svsrao Quote
Absolutely. It works much more than manual, or even auto.
Please read this thread. My post about the 200T is the first on on page 2:
AF200T and Pentax DSLRs
Note that in terms of camera compatibility, what applies to the AF280T also applies to AF200T.
04-14-2010, 05:11 AM   #5
Thanks a lot Peter,Nesster & SOldBear for your replies. Good information indeed.
Thanks again.
04-14-2010, 02:40 PM   #6
Mike Cash's Avatar
QuoteOriginally posted by Peter Zack Quote
...since neither of these flashes have adjustable settings for manual....
The AF200T has four manual power settings (and two auto levels).
flash, lighting, photo studio, strobist
Sigma 530 Super flash doesn't fire multi flash, any advice? pasipasi Pentax DSLR Discussion 4 11-25-2010 02:04 AM
For Sale - Sold: Pentax AF200S flash, Vivitar 2800 macro flash, Lowepro Lens case 4 Light_Horseman Sold Items 8 03-06-2010 10:13 AM
Can we set the internal flash of K-7 not to flash while connecting wireless with 360? raider Flashes, Lighting, and Studio 12 11-15-2009 09:31 AM
K2000 low light autofocus flash assist - without using flash Eruditass Troubleshooting and Beginner Help 21 08-24-2009 05:33 PM
For Sale - Sold: Pentax TC's, Kenko TC, SF10 (x2), AF540 flash, Promaster FTD 7000M flash Marc Langille Sold Items 17 08-16-2008 10:29 AM
All times are GMT -7. The time now is 02:32 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
