Ben:
Thanks.
You saved my bacon
I tried what you suggested with great success.
I simply dial in the ISO and aperture and it works
I even tried to bounce it off a high ceiling (about 3-4 meters high) and it worked. But I dialed 2 stops smaller f-number to get the result that I want.
I was using shutter speed 1/60.
I change the shutter speed to 1/160 and the result is similar (not underexposed).
Does the flash know that the camera's shutter is set to 1/60 or 1/160?
It seems that the flash auto-compensate for faster shutter speed.
Is this right?
The fastest shutter speed is 1/160. Above that, the flash won't fire.
What's the reason behind this?
cheers
