Originally posted by BethC I was all set to order the Lumopro LP 120 flash over the weekend and they were out of stock
But I really want a flash to start using for some fill on portraits, and especially want it for this coming weekend. So I ordered a Metz 48.
Anyone ever use both? and have any ideas if the Lumopro would have been a better flash? I figured if I'd rather the that one, I can always sell the Metz and hope to get enough out of it to cover the Lumopro and shipping.
The Lumopro is going to give you a lot more power, but whether you use that light or not is not something anyone can tell you. The Metz has power settings in manual from 1/1 to 1/128 in half stops, 1/1, 1/2, 1/4, .... The power setting is available without menu diving by using the two center buttons, left for less power, right for more power.
To manually set the zoom, you'll have to negotiate the two center button push to get to the menu. The zoom setting is only shown on the LCD in manual mode when the flash is in it "normal" locked position or in the lower -7 degree. The flash doesn't zoom if the wide panel is deployed.
Some settings are only set after five seconds. You have to wait for the flashing to stop on the LCD before proceeding. When using the flash off camera you'll probably want to turn off the auto power off. I am a little absent minded about the flash so just leave it at 10 minutes.
The tilt seems to lock at each setting on my flash and requires the lock to be pushed. When on the camera, I grab the head, placing my thumb on the lock button, and then rotate the head clockwise before adjusting the tilt. This just seems easier as the action is all in the wrist and not at the elbows.
It you end up using wireless P-TTL, remember that the wireless sensor is behind the little window under the battery door, not at the front as with most flashes. To change batteries, place your left thumb on the battery door when sliding it open or closed. This relieves the force on the plastic hinges and should keep your flash in good shape for a long time.
You probably won't be able to put in all four batteries at the same time. There are two that sit a little under the lower protrusion on the door when it is open and you have to get them in and under that before the next two. It may sound silly, but I read on one review where the reviewer complained about the battery direction not being easily defined. It actually is however, clearly indicated on the metal posts on the battery door. You'll see the + and - for each battery. You can also look into the battery compartment and see the positive posts in red and the negative in black.
The Metz 48 does lack a PC port, so if you are going to need a pc connection, you'll need a shoe with a pc port. I have simply been using the hot shoe on the radio trigger I have.
Hope everything goes well with your new flash.
Thank you
Russell
