07-25-2011, 12:39 PM - 1 Like   #1
yeatzee's Avatar
SMC/S-M-C/Super-/Auto-/Takumar 55mm F1.8 samples
Mines the Auto variation
08-04-2011, 02:44 PM   #2
Pepe Guitarra's Avatar
great lens
10-26-2011, 03:39 AM - 2 Likes   #3
KarenH's Avatar
I've got the Super version.
Just got it 1 week ago, didn't take much pictures with it yet, but I already know I'm going to love it.
It's a little bit soft wide open, but sometimes that's just what you want.
10-26-2011, 10:12 AM   #4
Nesster's Avatar
The 55 is a really good lens, and not just for the money.
Here's an illustration of what SMC coating can do:
two from the Auto
some from the SMC with film:
...and the SMC on a K100D
04-17-2012, 07:23 PM   #5
Super Takumar 55mm 1.8
A few samples from this lens ;
More to be seen here :
Insert Photos and Images
07-26-2012, 11:17 AM   #6
Very thin DOF
Difficult to focus, may be katzeye screen, but the color rendering and OOF transition is incredible. I'm lucky to have one of this lens.
Mine is SMC Pentax version, the photo was made with +0.7EV, 1/80th second and F1.8 aperture.
PENTAX K-5  Photo
10-15-2012, 06:34 AM - 1 Like   #7
zantaphia's Avatar
Too few photos here with this killer razor katana sharp lens!
SP 2 and 55/1.8
11-23-2012, 06:55 AM - 3 Likes   #8
02-06-2013, 05:01 AM   #9
BKSPicture's Avatar
Technical info
Camera: Pentax Spotmatic SP II
Lens: S-M-C Takumar 55mm f/1.8 + macro tubes
Film: Rollei RPX 100
Scanner: Plustek OpticFilm 7600i
Place: Uddevalla / Sweden
HiRes ver of this picture can be found on my homepage: Picture: Macro & Flowers
02-08-2013, 12:13 PM   #10
How are those Takumars coping with high contrast fully open? I had bad experience with some old lenses showing noticeable hallos and glow.
02-08-2013, 02:17 PM   #11
durell: Lovely bokeh and everything else!!
02-08-2013, 09:04 PM   #12
QuoteOriginally posted by zantaphia Quote
SP 2 and 55/1.8
Nice image. But I am interested in the subject.
It looks very much like one of a class of 4-8-0 locomotive being manufactured in Australia for the Chinese railways at the end of the civil war. The remaining ones were converted for use on 5'3" and with local fuels - by then usually Leigh Creek coal with oil supplement to make it burn.
Do you know the original of the locomotive?
02-08-2013, 09:48 PM   #13
zantaphia's Avatar
QuoteOriginally posted by tim60 Quote
Hi!
I think it's built in Sweden? I'll check my other photos of if to see if I can find the manufacturing plate. However it can still be made from drawings coming from outside Sweden. I can't go there to check, because i'm living in China now.
BR Pär
02-09-2013, 02:08 PM   #14
Hi!
BR Pär
Sorry, I was tricked by your location,a nd thought it might be in China. I did think the backgorund unusual for China, but they do have 'theme' developments. I do know the ones not delivered on the aid contract were converted for use on South Australian Railways.
02-09-2013, 02:27 PM - 1 Like   #15
QuoteOriginally posted by george2013 Quote
The earlier series of Tak lenses, all before multi coated in the name, were single coated lenses. I have noticed that they do suffer challenges with high contrast edges where one side has a very bright light, such as light sources or sun. I live with it and usually enjoy it as part of the aesthetic of these lenses. I do not notice the challenge unless there is a very bright source on one side of the edge. A chessboard in normal light is high contrast but does not push the effect.
This was the effect which pushed th search for improved performance, which led to the multicoating treatment. I only have two multicoated ones (35/3.5 and 200) and have not usesd either much, so have not firm opinion.
Using a lens hood helps this effect.
There is another effect I noticed. The wide angle lenses all have small rear elements, which means there is a large rear surface. SuperTak and later lenses had this surface painted in the matte finsh for non-reflectiviyy. The only Auto Tak I have used (35/3.5) had a very smooth surface finished in a glossy finish (anodised?). This must have been acceptable in film, but in DSLR (K100DS at least) there can be reflection from the sensor (which is basically glass with reflective bits on it) rather than the less reflective emulsion of film. The frlection in the auto tak then reflects off the back of the lens and results in a generalised fogginess leading to poor contrast, not quite the effect you describe. The effect was less in dull light, but still noticable. I normally use these lenses with Av mode, and +1.3EV to get consistent good exposure. The AutoTak demanded to be set at +0.3 or ).6 to work reasonably, but that only disguised the effect, did not remove it.
I have the 55/1.8 and 55/2, both STak. The f1.8 is in better condition, and is nicer to use. The f2 was my first normal m42 lens, and got me hooked. I bought a cheap one just to find out how it would go, technically, could I get it to work OK. I had to open the f2 to remove some adhere muck on an inner surface. It is very easy to remove the glass for cleaning, and designed so it can only be assembled correctly.
55mm, 55mm f1.8, auto, camera, f/1.8, flickr, pentax lens, sample photo, takumar, yeatzee
smc PENTAX DA Star 55mm F1.4 SDM SUPER SLOW Auto Focus with K-7 brosen Pentax SLR Lens Discussion 21 05-15-2013 08:48 AM
Auto-Takumar 55mm F1.9 travfar Pentax SLR Lens Discussion 19 07-12-2010 09:13 AM
120/2.8 SMC Takumar samples? d.bradley Pentax SLR Lens Discussion 3 11-01-2009 01:59 PM
Super Takumar 135mm f/3.5 and Super Takumar 55mm f/1.8 Fixcinater Pentax SLR Lens Discussion 21 08-30-2009 09:34 AM
Match 11: SMC Takumar 1:1.4 50mm vs. Sears Auto 1:1.4 f=55mm carpents Pentax SLR Lens Discussion 11 07-13-2007 10:17 AM
All times are GMT -7. The time now is 09:38 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
