07-28-2011, 05:26 AM   #1
altopiet's Avatar
Cosina 100-500mm 1:5.6-8 MC Macro
I got this lens for about $20. It has no zoom creep, I would rather call it zoom RUN.
No PP, just resized from RAW to JPEG
The lens
Two bird photo's taken at between 450+500, and f5.6, with my K-x, using CIF
1. At 1/1000, ISO 1250
2.
This is a heavy lens, I still have to try it hand held
07-28-2011, 07:15 AM   #2
Wow what a steal, congrats on the great deal. You will make RioRico so jealous. 20 is probably the scrap metal price alone for that beast.
07-28-2011, 08:33 AM   #3
altopiet's Avatar
QuoteOriginally posted by kenafein Quote
I must say I do take his advice of bid low and bid often! The problem with this lens is that I'll most probably have to go to gim before I can try decent hand held shots, and that would cost an arm and a leg
09-10-2011, 10:55 AM   #4
Promaster Version
I bought the Promaster 100-500mm f5.6-f8 (Same lens - different badge) back in May and decided it was time to try it out. I bought the lens off Craigslist for $20 and about $20 in gas to pick it up.
The reason I got it so cheap was that there was an issue with the barrel and I could only operate the zoom from 120-500mm. When I got it home, I discovered that the barrel had a big screw mark under the collar thread that attaches to a tripod. I figure someone tighten the collar to tight or someone's tripod screw was too long. Either way, it probably put a flat spot on the barrel. To add insult to injury, when I was removing the Ricoh pin, the steel ball that locks the aperture in the A position fell out and turned my A lens into a M lens.
Enough talk, here are a few shots I posted in the long lens club (with mono-pod).
Somewhere in the 400-500mm range
300-400mm range
Not really sure.
500mm with a little crop
Post processing wasn't much different from my normal processing with my Kit lens.
Tim
01-06-2022, 11:31 PM - 2 Likes   #5
Sagitta's Avatar
Picked this lens up in late summer this year for just under $100. The lens is DEFINITELY worth more than that for the results it produces.
camera, cosina 100-500mm, lens, pentax lens, sample photo
Suggestions on finding the Matched 1:1 Macro Adapter for Cosina 100mm f/3.5 Macro? pentaxk1000denver Pentax SLR Lens Discussion 10 06-18-2011 02:41 PM
soligor or cosina 100/3,5 macro ewig Pentax SLR Lens Discussion 7 02-03-2011 06:35 AM
Nature Birds with the Cosina 100-500mm Xsalfior Post Your Photos! 3 04-16-2010 07:02 PM
Wanted - Acquired: 100-400mm, 100-500mm, 150-500mm or similar K-mount lens GibbyTheMole Sold Items 8 12-03-2009 11:52 AM
Just got a cosina 100-500mm Xsalfior Pentax SLR Lens Discussion 4 11-13-2009 01:22 PM
All times are GMT -7. The time now is 11:00 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
