Hello.
I was looking for something longer than 135mm lens for quite some time. I have sigma 70-210mm but this one has some issues ( not fast - 5.6 at long end and above ~180mm not really usable). So I was hunting for some time and finally I found an interesting Praktikar 200mm f2.8 M42 screw lens from local Sunday market for mere £15. It is a very heavy lens - weights with a hood attached over 1260g. It had bad fungus inside which I cleaned - but sadly also the aperture ring appears to be very stiff and not smooth at all - I am however unable to find a way to disassemble the mechanisms so can't even try to fix it. Anyway after I cleaned it it and tried with my K-01 it came out quite nice - I was surprised to see this good results with it at full aperture. Below are samples with full 100% crop inserts for you to judge.
Is it good enough for good results in low light situations if compared to modern lenses - or shall I dump it and I should shell out the cash for something modern in this range?
Thanks for all responses - samples of similar telephoto lenses are welcomed for comparison
The image below was taken with my K-01 handheld and F 2.8 - I only look for comparison of similar or faster lenses.
Reason: Title changed
