10-02-2013, 12:25 AM - 1 Like   #1
K David's Avatar
Takumar 67 55mm 1:3.5
With an enormous 100mm diameter filter ring, the 55mm 1:3.5 presents a challenge in finding filters. That drawback, however, is offset by the lens' cinematic light rendering quality. At no time and in no part of the frame does this lens ever appear to lose control of the light passing through it. As an added bonus, it looks pretty amazing on a Pentax 6X7.
With TMax 100
10-02-2013, 02:23 AM   #2
Banned
uppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppp
10-04-2013, 08:11 AM   #3
Lowell Goudge's Avatar
what are the apparent interference rings on the B&W shot of the cactus?
was this a glass mounted frame?
it does not show in any of the other images with this lens, but also show up on the 105mm image of the cactus/
10-04-2013, 10:14 AM   #4
K David's Avatar
Back when I was still refining my medium- and large-format digitization process (I used my K-7 and a macro lens because it performs better than a scanner) I had problems keeping the negatives flat. So I used a piece of glass. That led to those banding lines on images. Since then, I've switched to a negative mask from an old Honeywell Repronar and that works VERY well. No banding and near-perfect negative flatness. I suspect an old negative carrier would work well, too.
55mm
Hood for Takumar 6x7 3.5 55mm ChrisFe Pentax Medium Format 3 06-11-2012 10:50 AM
Super Takumar 135mm f/3.5 and Super Takumar 55mm f/1.8 Fixcinater Pentax SLR Lens Discussion 21 08-30-2009 09:34 AM
All times are GMT -7. The time now is 11:12 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
